Z Z270 Prominent Apr 13, 2020 6 0 520 Apr 13, 2020 #1 RAM 2 X 16gb DDR4 3000mhz Teamgroup Vulcan Z Red does not work in XMP mode and the computer does not start. If 1 X16 works in XMP 3000mhz mode and the computer starts without problems .Asus Prime z270-P. can I help who? (sorry for my bad english)
Solution Z Z Z270 May 19, 2020 it is solved. tension 1.20v till 1:50 v and change of timings on 19-20-20 - 40CR1 helped with dispersal of memory to 3533Mhz (sorry for my bed english)
Nemesia Splendid Nov 6, 2019 5,781 1,245 23,390 Apr 13, 2020 #2 Your 2 sticks should be seated in A2-B2 as per your manual. Make sure the RAM are seated in those slots and properly seated in the slots. If they are seated in the A2-B2 slots and you still have issues try updating the BIOS. What version of the BIOS are you running right now? https://imgur.com/a/TFUaxPS View: https://imgur.com/a/TFUaxPS Upvote 0 Downvote
Z Z270 Prominent Apr 13, 2020 6 0 520 Apr 13, 2020 #3 bios 05 .11.2018 Tried in different slots the result is the same Last edited: Apr 13, 2020 Upvote 0 Downvote
Nemesia Splendid Nov 6, 2019 5,781 1,245 23,390 Apr 13, 2020 #4 Z270 said: bios 05 .11.2018 Click to expand... 1006, 1010 or 1025? Version please. Not the date. Upvote 0 Downvote
geofelt Titan Oct 9, 2006 54,291 4,145 174,240 Apr 13, 2020 #8 Have you overclocked your 7700K? As I recall, I had a similar issue in that ram speed impacted my overclock. Are your two ram sticks from the same kit? Ram must be matched. I might add that raid 0 for a ssd is not good for a variety of reasons. Upvote 0 Downvote
Z Z270 Prominent Apr 13, 2020 6 0 520 Apr 13, 2020 #9 Memory was in the same set 2 Х16 Upvote 0 Downvote
Z Z270 Prominent Apr 13, 2020 6 0 520 May 19, 2020 Solution #10 it is solved. tension 1.20v till 1:50 v and change of timings on 19-20-20 - 40CR1 helped with dispersal of memory to 3533Mhz (sorry for my bed english) Upvote 0 Downvote Solution
