2 x 6 pin PCIe power connector
Paleozoik
6
I bought corsair CX500M power supply and a Gigabyte 270x graphics card. Now the problem is. Since the PSU is semi-modular it has 6 pin peripheral, 6+2 pin PCI-E, 6 pin SATA, and 4+4 CPU. Now, how can I connect my PSU to a graphics card with 2 x 6 pin?
That PSU comes with 2 x 6+2 PCIe power so none issue use both 6 pin parts http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
There is no 6 pin peripheral only 4 pin and it is also called MOLEX.
Ok, but here are my cables: 8 pin (type 3) on one end (that end goes into PSU), and 2 x (6+2 (it sais PCI-E on the 6 pin) on the other end. And one with 6 pins that goes into PSU and 4 molex and 1 weird one (I think it's for floppy) on the other end, also the 2 of 2 molex to 1 x 6 pin that I've got with the graphics card
So I'm about to use the cable that has 8 pins on the side that goes into PSU and 2 PCI-E off the other end and into my graphics card. If I got it wrong will it fry up my gpu or will it not work?
High end cards have 1 or 2 8 pin connectors and then the 2 pin is plugged in with the 6 pin making a 8 pin connection.
