2 x EVGA GTX 1060: one or two fan model better?
I plan to replace two GTX 950s inside a computer case with two GTX 1060's.
* The two cards will not be in SLI. Each will be devoted to one VM each, so SLI is not a factor.
On one hand, I imagine that the dual fan design will be better at cooling, with two GPUs next to one another. On the other hand, the single fan GPU is shorter (6.8" vs 10.10") therefore it should help promote better air flow inside the Define R5 case. Thoughts?
*** image of the two GPU dimensions ***
I'd go for the single fan 1060 SC. Do make sure to get the SC and not the regular model as the SC has a much more capable heatsink. The non-SC's heatsink looks like a stock Intel cooler, while the superclocked has copper heatpipes and denser grid-pattern heatsink fins.
I would go with 2 reference/blower style cards as from what I have read they cool better in close SLI configurations. The founders edition is an option and some board partners have custom blower designs.
There is no official support for SLI 1060's I would recommend against it.
Please read the start of this review to be sure this is a path you wish to take.
I get the feeling that sli will be supported in the future but the games it seems will require "The GTX 1060s do not have SLI fingers and can only communicate via the PCIe bus, without a bridge, thereby demanding that applications support MDA (Multi-Display Adapter) or LDA Explicit (Linked Display Adapter) to actually leverage both cards. "
http://www.gamersnexus.net/guides/2519-gtx-1060-sli-benchmark-in-ashes-multi-gpu
I would have a read and see if it's worth it.
OP must've accidentally wiped out his first post when he edited, but it's already been stated that he's NOT looking to SLI, he's going to use the two GPUs to run two individual virtual machines, and is seeking opinions on which model card would be best for decent temps/airflow in the case.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor ($179.99 @ SuperBiiz)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard ($101.88 @ OutletPC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($69.99 @ Newegg)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive ($169.99 @ B&H)
Video Card: EVGA GeForce GTX 950 2GB SSC ACX 2.0 Video Card ($129.99 @ Newegg)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case ($84.99 @ NCIX US)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply ($135.98 @ Newegg)
Total: $872.81
Generated by PCPartPicker 2016-08-28 16:28 EDT-0400
The ASRock Z170 Pro4S will leave at least one whole slot width of empty space between the two graphics cards as long as you don't use the PCIe x1 slot that is situated between the two PCIe x16 slots.
That's plenty of breathing space to allow the graphics card closest to the CPU to get sufficient air intake.
Sure. What do you wish to know?
EVGA GeForce GTX 1060 6GB SSC
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487275&ignorebbr=1
Although I must admit that the parameters of this question have changed since I originally posted it. At that time the single fan version was $260 and the twin fan was a good deal more. Now the single fan version is $270 and the double fan is $285; only $15 more. I plan on purchasing a GTX 1060 as a gift for a friend, and I'm seriously thinking about getting them the dual fan version. For $15 more, it's one of those "might as well's".
Not sure where you got those prices, I'd debating on buying a EVGA GTX 1060 for 240 or the dual fan for around 290 so it's more of a difference there lol
Whats the difference between the SC and the other one thats not SC?
The non-SC version uses NIVIDIA's reference design clocks.
The SC version is factory overclocked by 6.7% on the base clock and 7.4% on the boost clock.
