Question 2 x Molex 4 pin to 8-Pin for vega 64
Jun 21, 2019
7
Math Geek
Glorious
Herald
no. if your psu does not have the needed connections, then it is not capable of powering the card, no matter what adapters you use. changing the physical look of the connection does not create extra power.
you need a new psu that can handle the system it is trying to power, plain and simple.
Karadjgne
Herald
Doctor says you need a new heart, if you even walk as far as the bathroom, it'll likely kill you. MacGyver comes along and says he's got some Legos and duct-tape, he'll build you a new heart easy....
Really, that's exactly what's goin on. Adapters. If your psu does not have the correct connectors, it only shows 1 thing. The company has zero faith in that psu's ability to power that gpu.
Use them if you wish, but when your pc starts smoking and there's a definite burnt plastic smell in the air, you were warned. Bye bye $400 gpu. Bye bye cheap psu. Bye bye pc.
