20+4 pin power supply and 8-pin motherboard
Mar 21, 2018
11
Ok, I'm sorry if this is a stupid question, but I'm trying to make my first pc build and there's something I'm not sure about... I ordered a 650W Corsair RM650i silence power supply (24-pin) and the motherboard is Asus Prime Z370-P (8-pin). I also want to install Intel i7-8700 CPU. So, I'm wondering - is this PSU suitable for this configuration? Thanks.
Yes, it has both cables. Note that it has 2 different types of 8-pin plugs, make sure you use correct one for CPU and for graphic card. While they don't fit into wrong slot, but some people were creative enough to make it happen anyway.
You're right, thanks.
