C cptkurig Prominent Jun 19, 2017 5 0 510 Nov 20, 2017 #1 My 20 pin Asus motherboard won't connect with my 20 pin slots for the power button. And trying the screwdriver trick doesn't work I am using the A10AC case made by asus and Prime H270-Plus motherboard
rocktalkrock Judicious Jul 4, 2017 6,077 280 36,640 Nov 21, 2017 #2 Are you talking about the front panel connection pins on your motherboard, that your PC case power button plugs into? Upvote 0 Downvote
rocktalkrock Judicious Jul 4, 2017 6,077 280 36,640 Nov 21, 2017 #4 1. Look close, do you have any bent pins on the motherboard connection? 2. Is the connector turned the right way round, do you need to reverse it? Upvote 0 Downvote
C cptkurig Prominent Jun 19, 2017 5 0 510 Nov 21, 2017 #5 No pins are bent. which ever way I try to plug it in, there's is a blocker on one of the ports on the connector that doesn't fit Upvote 0 Downvote
