Just opened my DELL to put in a new PSU. Motherboard has a 24 pin connector with an additional little plug toward the back, which the new PSU seems to also supply. The problem is the new PSU only has a 20 pin mobo connector.
I've also just bought a dedicated graphics card, Radeon HD 7770. The computer was previously using integrated.
Can I use this power supply? Is there a particular way to connect it. Line up the top? Line up the bottom/ Stick it directly in the middle, leaving 2 pins open on both sides?
New PSU is a Seasonic S12II (Bronze), 520W ATX 12V.
Mobo is a PCI-E Gen.2 G43T-DMI V:A00
Thanks
Thanks
