I'll be using an 1166 motherboard (full size Gigabyte ATX) with a core 2 duo CPU at about 2.5ghz. Can't remember the model numbers. Probably using 4gb of 1600mhz DDR3 ram on XP 32bit. Hard drives will be 1 SSD and 1 Sata 7200rpm 1tb. No optical drive, 2 fans. I've found that fans and hard drives don't make much difference so the main things are the motherboard, CPU and ram. Wondering if this could be powered by a Pico 200 watt power supply. And is there any way of supplementing that power with an AC adapter? I realize I could power the fans with an AC adapter but fans really draw almost no power. And I think the optical and hard drives require a more sophisticated power source than an AC adapter. I'm aiming for maximum power efficiency of course.
Otherwise they'd get in twubble!
