$2000+ system build.
hercules
88
I am building another new system.
No need for monitors keyboard or mouse.
Everything needs to come from Umart.com.au so its all in aussie dollar
Case: Xclio A380 Super Tower
CPU: Intel Core i7 920 Processor LGA1366 2.66GHz 8MB Cache CPU
Mobo: Not sure something with a decent on board sound card. maybe igabyte GA-EX58-UD4P MB
Ram: Depends on if i get a ddr2 or 3. I personally don't mind spending a bit more to get ddr3 maybe OCZ 4G(2x2G) DDR3 Reaper 1600 PC12800
HDD: Samsung 750G SATA II 7200rpm 32M Ill buy and second one when its needed.
PSU: Antec ATX TruePower 650W
Cooler: Master Hyper N520 Cooler support LGA1366
GPU: Gigabyte GTX285 PCI-E 2.0 1GB DDR3 Dual Dual-Link DVI HDCP Fan
DVD: LG DVD22X+- DUAL LAYER DVD Rewriter with Software(GH22NP10)
$2014.00
But feel to suggest upgrades or even downgrades as you wish
Also if you think i need a sound card we can add that in
Also
Vista 32 bit
2 monitors 19 inch and 24 inch both run at 1920X1200
I am using to play games. I hate long load times and i run Xfire msn all my anti virus stuff ect on my 19 inch with the game ( in windowed mode if its the correct type of game) on the 24 inch
I more than likely wont be upgrading to windows 7
Future Sli is always a possibility
I want to use Nvid Intel Gigabyte where ever possible
I also will be looking at new speakers. I have my eyes on Logitech Z-2300 THX 2.1 Speakers System
Logitech Z-5500 THX Digital Speakers System is nice but twice the cost price.
Thanks for your help! Take your time reviewing I am in no rush to buy This new PC
astrodudepsu
340
if you are going with an i7 and the UD4P you will need triple channel DDR3 (in other words 3,6,12GB). so having dd2 isn't even an option.
HDD: The house favorite around here are the WD Cavair Blacks in the 640GB models. They have higher platter densities than 750GB models and thus are a bit faster. Although these days any 7200rpm drive with a 32MB cache will do fine.
if you want to future SLI with that GTX285, you are going to need a bigger PSU. I believe 850W of a GOOD PSU is recommended for 2 285's. The 850W Corsair or Antec models for instance.
hercules
88
i might just buy a bigger psu when i buy a second 285. I wont be buying another 285 till they are dirt cheap. I dont thin Umart stocks taht type of HDD. So am i going to have to buy 6gig worth of ram even thought 32 bit wont be able 2 read 2 gig of it?
astrodudepsu
340
oh gosh, I didn't even see that 32bit OS. Any real reason for that? Unless there is a specific pressing reason for you running 32bit Vista, just get the 64bit version.
If you are insistant on running 32bit Vista then you will need 3GB of DDR3. Any more would be wasted.
I would either go with XP 32 bit or vista 64 bit. Vista 32 bit is garbage.
With an i7 board, you need DDR3. Triple channel is the ideal setup. You can go 3gb or 6gb depending on your OS choice.
a 32 bit system will recognize ~3.25gb of RAM.
astrodudepsu
340
Actually less, because his video card alone has 1GB vram.
hercules
88
The only thing is I have a vista 32 bit cd's ready to use.
Microsoft Windows Vista Home Basic 64bit(OEM)purchase with Hardware Only
Internet Price: $159.00
Here is the main problem I am taking the hard drive out of this PC and putting it into my new one. Then i am putting the new Hard drive into THIS pc and giving to my brother. How hard is it to uninstall a OS and install a new one with out whipein the HDD? Also THIS PC works fine with 32 but as it's only 4gig ram. I need to make the purchase by at least Thursday for tax purposes.
hercules
88
I updated my last post I dont mind buying the 64 bit. My only concern is I have read occasionally it isn't as compatible with some games. Also windows 7 wont be compatible with many games at all?
Virtually every game that runs on vista 32 bit will run on 64 bit. There isn't much driver support for windows 7 yet. Software always lags behind OS's.
Is it worth buying vista 64 though when windows 7 will be out in a few months?
hercules
88
how much is 64 bit windows seven going to cost?
maybe i should just stick with the 32 for a few months then upgrade to the windows 7 but ill buy the 6gig and wait for 2 months? Apart from that the hardware i listed is it all compatible?
micky_lund
672
dont even think about 32 bit... pay the extra and get 64bit.. and wait for W7, it'll be worth it, and from what i've heard, they've fixed the stupid compatibility issues
btw: good to see a fellow aussie on here :D
hercules
88
Haha i often browse the front page head lines. Wouldnt it be a rather large waste of money spending 150 to get the 64bit just to upgrade to windows 7 two months later? I would prefer to put the 150 into a better sound system or even better hardware?
mdale13
81
that is a weak setup for $2000. you need to reassess your parts. i am building a system right now that is every bit as good as that, but $400 less.
hercules
88
You need to remember that i am Australian so everything over here is that bit more expensive... feel free to go to umart.com.au and make something better for 2000
hercules
88
No problem mate! So can anyone see any place where i could change hardware or would they like to suggest a type of ram i should use? I think ill just install my vista 32 for the 2 months then buy windows 7 64 i have survived on 32 for this first 6 months of the year
hercules
88
Also on another forum someone suggest a SLI 2 275's for better results i dont mind doing this. Will i need a bigger psu and what ones should i use?
micky_lund
672
SLi 275's will easily beat a SINGLE 285, but SLi 285's will beat SLi 275... its all up to you, but id go with 1 or 2 GTX 275, better price for the performance
