2008 Jeep Liberty not charging, alternator and battery replaced.
hammer326
96
It died last night when parked at work, unsure how, asking on their behalf. I'm told the alternator and battery have been replaced. After googling for a good 20 minutes I've read everything for potential culprits from a bad alternator to corrosion on the cables. Aforementioned relative insists that can't possibly be it, but we know how that goes. I also remember being told something about the multimeter reading around 11 volts.
Happy to acquire more info as is requested, and as always, all help appreciated.
Thank you!
Ralston18
Not a waste of time.
Unfortunately, the overall quality of many things is dropping and even a new device (e.g., an alternator) can be faulty. Or quickly fail.
Other people may read the above and discover that there is a fix and that relatives, no matter how stubborn, can be wrong. Know one such person myself - logic and proof does not matter to him.
Key is good troubleshooting and an open mind. Ignore the closed minded folks.....
Greg Gregorich
871
49
two simple alternator checks 1. is start the car (in a dark time dont recommend doing this in not ventilated areas like garage or small werhouse ) turn lights on find switch for defrosters fan turn high beams should show blue light on dashboard of the car then turn defroster fan on high if the lights DIMM A LOT that sign alternator problems 2. start the car remove positive or negative cable from battery if the engine shuts off you have problems with alternator
mymutter
135
30
Never disconnect the battery on a car that is running, This could cause thousands of dollars of damage. Don't let anyone ever give advice or work on your car if he feels this is okay. Cut and pasted from Steve Litt who says it a lot better than I do.
"Your battery does more than just provide electricity. It also shorts AC, spikes and transients to ground. Removing the battery from the circuit allows those spikes and transients to travel around, endangering every semiconductor circuit in your car. The ECU, the speed sensitive steering, the memory seat adjustments, the cruise control, and even the car's stereo."
I have known someone who tried this and they got off easy with a $250 PCM rebuild. It's not the 70's anymore, this is just not done.
My bet is on the battery failing, occasionally new ones do fail as well, but it's rare.
Charge up the battery, start the vehicle and measure the voltage. If it's above 14 the alternator is good, if it's around 12, the alternator is the culprit (or wiring, but that's easy to check, don't forget to check the ground from the engine, but a multimeter is an easy way to verify the cables are good)
If the voltage is 14, then it's most likely the battery, but could be other things as well. Does the jeep have an aftermarket stereo and amplifier installed? were the lights left on, is something else draining the battery..
BFG-9000
Besides the usual fusible link near the starter that can cause this (it's often buried in the loom nowadays), Jeeps often have a thermistor under the battery tray to prevent charging when the battery is too hot. If that gets broken or corroded, the PCM will think the battery is too hot to charge.
hammer326
96
Thanks so much all around guys, a few days and multiple tech friends visiting later.....The replacement alternator was bad out of the box, we acquried another and are good to go. This was something the aforementioned relative I'm helping out refused to acknowledge was possible despite like EVERY other thread about this issue suggesting it either 1st 2nd or 3rd as a troubleshooting step. Sorry to waste your time.
Ralston18
