W web.prohlizec Prominent Sep 22, 2017 2 0 510 Oct 10, 2017 #1 Hi there, can you please help me to find FAN with these specs ? 200CFM+ 120mm 4 pin 60DB and lower
Solution Aeacus Oct 11, 2017 At those specs, you need to look towards industrial fans. Here's one that comes close: Delta AFB1212GHE-CF00, 120mm, 3-pin, 241.0 CFM, 62 dB(A), specs: https://www.digikey.com/product-detail/en/delta-electronics/AFB1212GHE-CF00/603-1325-ND/2560449 pcpp: https://pcpartpicker.com/product/dnPfrH/delta-electronics-case-fan-afb1212ghecf00 Or Delta QFR1212GHE, 120mm, 4-pin, 210 CFM, 64 dB(A), specs: https://www.digikey.com/product-detail/en/delta-electronics/QFR1212GHE-SP01/603-1165-ND/1850534 aliexpress: https://www.aliexpress.com/store/product/Free-Shipping-Delta-QFR1212GHE-12V-2-70A-12038-12CM-4-line-server-cooling-fan-Wholesale/518335_1385417446.html You can also use Digi-Key search filters to find a more suitable fan from the listing.
Aeacus Titan Mar 21, 2015 14,052 2,572 84,890 Oct 11, 2017 Solution #2 At those specs, you need to look towards industrial fans. Here's one that comes close: Delta AFB1212GHE-CF00, 120mm, 3-pin, 241.0 CFM, 62 dB(A), specs: https://www.digikey.com/product-detail/en/delta-electronics/AFB1212GHE-CF00/603-1325-ND/2560449 pcpp: https://pcpartpicker.com/product/dnPfrH/delta-electronics-case-fan-afb1212ghecf00 Or Delta QFR1212GHE, 120mm, 4-pin, 210 CFM, 64 dB(A), specs: https://www.digikey.com/product-detail/en/delta-electronics/QFR1212GHE-SP01/603-1165-ND/1850534 aliexpress: https://www.aliexpress.com/store/product/Free-Shipping-Delta-QFR1212GHE-12V-2-70A-12038-12CM-4-line-server-cooling-fan-Wholesale/518335_1385417446.html You can also use Digi-Key search filters to find a more suitable fan from the listing. Upvote 0 Downvote Solution
