2012 60hz monitor
Jun 6, 2018
12
Alright what's up guys! So I've just upgraded my specs to a gtx 1060 and ryzen 5 1600x. My gamplay's fps is around 200+ in fortnite competitive settings, but the thing is the game itself running looks very bad. Stuttering and all around feeling sluggish and slow.
Is there a chance that I need to upgrade to a newer monitor?
Higher refresh rate monitor to view so many fps would definitely help otherwise you would use vsync in NvidiaCP to smooth video but it caps the fps and refresh to your monitor which it'll give you smoother video but there's input lag.
For now if you want no stutters or screen tear and no input lag use Nvidia Inspector to limit fps to 59 and in NvidiaCP turn on vsync. You'll have no jitters and no input lag from vsync being on as limiting to 59 isnt at max refresh so there's a bit of give and don't notice the side effects as input lag.
https://www.guru3d.com/files-details/nvidia-profile-inspector-download.html
