2016 Desktop Build
stuarterb
Commendable
Aug 24, 2016
19
I'm working on putting together a new desktop gaming PC build. I'm looking to order the parts in a couple weeks. Any help I can get to make sure I'm getting the most bang for my buck would be appreciated.
Here's what I'm looking at:
MSI GeForce GTX 1060 DirectX 12 GTX 1060 GAMING X 3G 3GB 192-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready ATX Video Card
AMD FX-8350 Black Edition Vishera 8-Core 4.0 GHz (4.2 GHz Turbo) Socket AM3+ 125W FD8350FRHKBOX Desktop Processor
ASUS Z170 PRO GAMING LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM
Kingston SSDNow UV400 2.5" 240GB SATA III TLC Internal Solid State Drive (SSD) SUV400S37/240G
Thermaltake SMART Series SP-650PCBUS 650W ATX 12V 2.3 80 PLUS BRONZE Certified Active PFC Power Supply
G.SKILL Ripjaws V Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C16D-8GVK
Phanteks PH-TC14PE_BK 140mm UFB (Updraft Floating Balance) CPU Cooler
ASUS 24X DVD Burner
I'm looking for a case with at least 3 120mm fan slots and a few drive slots on the front. Any recommendations for that would be greatly appreciated as well. Is there anything else I can change to optimize this build?
Here you go.
If you add $30 to your budget, I can put in a 240GB SSD and a 1TB HDD.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($204.99 @ Newegg)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard ($56.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($60.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($61.00 @ Amazon)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card ($428.89 @ OutletPC)
Case: Zalman Z1 ATX Mid Tower Case ($24.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($58.99 @ SuperBiiz)
Total: $888.83
Generated by PCPartPicker 2016-08-30 07:00 EDT-0400
Here you go! :)
To be honest, a 2TB HDD is the best choice for gaming PCs if you store lots of high file size games like GTA, The Witcher etc. and it's only $10 more, so if you feel you need that space upgrade to this: http://pcpartpicker.com/product/KyCwrH/seagate-internal-hard-drive-st2000dm001
Apart from that you're set! Enjoy! :)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive ($59.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Total: $935.31
Generated by PCPartPicker 2016-08-30 07:39 EDT-0400
Hey Chugalub_ you've been more than helpful, thanks a lot! The only other question is if there's anything comparable to the GTX 1070 that would be more cost effective?
Here's my opinion on what you should go with,
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($198.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H170M-DS3H Micro ATX LGA1151 Motherboard ($75.38 @ Newegg)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2133 Memory ($51.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($88.48 @ Newegg)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card ($409.99 @ B&H)
Case: Enermax OSTROG ATX Mid Tower Case ($47.99 @ SuperBiiz)
Total: $979.30
Generated by PCPartPicker 2016-08-30 07:54 EDT-0400
Not really, no.
It's either 1070 or the next step down which is the 1060, which is about 65% of the 1070s power i'd say.
I recommend just sticking with the 1070. :)
