Question 2060 mobile low fps WARZONE
Apr 9, 2021
8
My laptop Asus TUF Gaming FX505DV is performing very badly as you can see from the benchmark https://www.userbenchmark.com/UserRun/41866598.
On warzone i can get only an average of 35 fps on the Verdansk map with setting medium to low.
I already changed the ram but there is no way to activate xmp on my bios... any suggestion?
The main issue with that benchmark is the laptop is using the integrated graphics and not the 2060. When you ram the benchmark was the laptop plugged in to the power supply and was Windows power plan set to high performance?
akimikage
166
26
If your on Win 10, you could try going to System>Display>Graphics settings >Choose an app to set preference click Browse and navigate to Warzone's folder and select Warzone's exe. Click Warzone's icon and press Options and select High Performance.
Apr 9, 2021
8
yes i did it already
Apr 9, 2021
8
You can use MSIAfterburner to monitor gpu usage over time. How do you know the 2060 is working in games and it is not just the benchmark that it is not?
i set up already win to use it and i can see that from the icon in the notification area... the only thing is that actually the performance is poor
