Question 2080 super power consumption?
KingC12
65
So I've just bought a second hand 2080 super and plugged it in fans started spinning, but didn't post, fans went off nothing.
Tried it in another pc with a rx750x and it worked instantly, he uses a 7700k and I use a 3700x if that changes anything. How much power does the 2080 super use?
I have 3700x with stock cooler
X570 msi board
32gb corsair vengeance ram
500gb m. 2 drive
2tb ssd
Should I order another power supply? I tested everything the other day with a 1060 6gb and everything worked. But the 2080 super nothin
KingC12
65
Can you try a different psu cable?
Yeah I've tried a different psu, different cables as both of our psus are modular, I tried the cable that works on his in mine. But I don't think the psu is the issue. I think my board is dead, everything that works in his pc doesn't work in mine. But one thing I can't understand is if it was the board why is the pc running but there is no display?
