I have two Asus 2080ti Turbo cards in SLI and their GPUs are drawing 40 watts and 20 watts at idle--this is when at the desktop with nothing open--not even a browser. Albeit I am running a 60 Hz 4k monitor, but I have seen numbers showing others running a 60Hz 4K monitor plus a second standard size monitor with only one 2080ti and their power draw on the GPU for the two monitors is only 24 watts. 60 watts total for one 4k monitor is a far cry from 24 watts for one 60 Hz 4k monitor plus a second standard resolution monitor.
I also use the same monitor with another computer that has two 2080s in SLI, and the power draw of the two 2080s at idle is half. There is also data showing that typically a 2080ti GPU uses one watt less power than a 2080 GPU at idle, so what the heck?
It just seems very abnormal. I know more higher end cards draw more power under load which is accounted for by higher performance, as in high FPS and such. But typically a 2080ti at idle draws one watt less than a 2080 at idle.
Here is a quote from the Nvidia forum:
My 2080ti is idling at 18W with extended desktop configuration over 2 displays and only 8W with a single monitor.
And from the EVGA forum:
My 2080 TI FTW3 Ultra idles at 16 w also.
