20pin power connector
dtranftw
68
Hi i am thinking of building a spare pc for my brother and i was wondering if a 20 pin motherboard cable will work on a 24pin motherboard.
My parts for the build are : AMD Athlon x4 760k, 4gb of ram , 500 gb hdd, an old ati 2400xt and a psu 400w atx
It should. It may be a bit hard on it, but the system should not need more than the power supply label lists(remember older power supplies start to loose some capacity so I would keep an eye on it.).
It is actually multi rail, but that is not an issue as such.
Lower powered cards may be a better long term bet(even a 5770 should take less and be faster), but for a second hand system, you work with what you have.
The 24 pins connector is a hold-over from the days before ATX12V and PCIe where the CPU and everything else on the motherboard was powered through the 20 pins ATX connector. The total current was pushing the limits on 3.3/5/12V and one extra pin for each were added to bring the average current per pin back down.
Now that nearly everything is powered by the 12V rail alone and that the major loads have their own dedicated 12V feeds, the 24-pins ATX connector is superfluous and serve little purpose beyond maintaining compatibility with PSUs that have 24 pins connectors. Most motherboards should not care whether those extra pins are there or not - they are all soldered to the same copper trace/pour/plane and that's it.
Straight 12 volt boards would be great. Only a few OEM's do this.
We still need 5v for some devices(usb/ssd/parts of the hard drive/ect). It sure could simplify things.
I have run many first generation boards without this issue. I wonder how many boards this effected. PCI-e does not even have 5 volts as far as I know and one of those extra 4 was 5 volts.
well i was planning to put a gts 250 in the x16 slot since the psu has a 6pin lead.
I checked on a wattage calculator and it said with the gts 250 i only need atleast 300 watts of the 400 i have
It is normally listed as 12v + 12vcpu must not exceed XXX watts or XX amps. They all show it a bit differently.
The reason it is important is your 400 watt power supply can not output 408watts(that would be if the rails added together. This rarely happens and as you can see it is more than the power supply is rated for)
Here is a multirail example image.
It would seem to have 30 amps(360 watts would be impressive from a 300 watt power supply) if you added the 2 12 volt rails.
It has 22amps(264 watts) combined. So as long as the 2 rails to not pass the set limits and the combined do not pass 264 watts, everything is good.
