24 inch, ips monitor
lukalukadjuric
Hi guys, i am looking to buy a new monitor. I would like it to be ips panel, because i love when open world games and other stuff look pretty. On the other hand i play dota 2 and fps games(not profesionally). Also, in my opinion perfect size of screen is 24 inches. I really need help to choose, especially because i dont know if i should go to 1080p or 1440p, and what refresh rate would be best for me. All advices are welcome!
My configuration is:
ASROCK AB350 Pro4
AMD Ryzen 5 1600 3.20GHz AM4 BOX
GIGABYTE GV-N1060G1 GAMING-6GD GeForce GTX 1060 6GB GDDR5 OC PCIE
CRUCIAL 8GB Ballistix Sport DDR4 2400MHz CL16 KIT BLS2C4G4D240FSB
KINGSTON 120GB SSDNow UV400 SATA3 2.5" SUV400S37/120G
TOSHIBA P300 1TB 7200 rpm 64 MB SATA3 HDWD110UZSVA
SEASONIC S12II 520W
Samsung doesn't know how to make PC monitors, especially gaming ones—it's great in T.V., but monitors, still meh.
The differences between TN and IPS panels, including but not limited to:
- TN standard has higher refresh rate—144Hz; standard IPS comes with 60Hz, 100Hz+ ones cost an arm and a leg;
- TN has moderate colours; IPS has more accurate colours;
- TN is very inexpensive, on the contrary to IPS;
- TN has the lowest input lag—1ms; IPS usually ranges between 4–8ms (1ms comes with a hefty price);
- TN is for competitive games' professionals; IPS for casual players who look for stunning view, and video editing professionals;
- IPS offers wider viewing angles with better colour accuracy, unlike TN panel.
For competitive gaming (Dota...
lukalukadjuric
Thank you for answer! I already told you GPU, and my budget is a 300 euros(20euros give or take). So this benq is fantastic but it is too expensive, the lg and aoc are tn panel... Is there any more suggestions? :/
For competitive gaming (Dota 2, LoL, WoW, CS:GO, PUBG, etc.), monitors with TN panel usually become the right pick because of their higher refresh rate, fast G2G (Grey-2-Grey) which determines input lag, and they have the least one—1ms—and they are insanely inexpensive. Something like ASUS VG248QE 24".
Your rig can run 1080p, 1440p, and slight 4K with no problem. But the less you run, the more FPS you get in games (this matters when it comes to graphically demanding AAA games), and the smoother the games become.
https://www.amazon.de/Dell-LED-Monitor-Reaktionszeit-h%C3%B6henverstellbar-schwarz/dp/B005JN9310/ref=sr_1_fkmr0_2?ie=UTF8&qid=1503529527&sr=8-2-fkmr0&keywords=Dell+UltraSharp+U2312HM+IPS+Monitor
https://www.amazon.com/Dell-UltraSharp-U2515Hx-LED-Lit-Monitor/dp/B00NZTKOQI/ref=as_li_ss_tl?tag=highgroundgaming-20&th=1&linkCode=sl1&linkId=2cf66270caa13ea9ae43e46374354961
https://www.amazon.com/dp/B00VERZDEG/ref=twister_B01MEHQ1QK?th=1
