24 or 27 inch monitor?
Mjakeman
7
Hello!
Im looking for a new monitor as my Dell 19' is nowhere good enough for my current system. I've had it for 6 years and its still working like a charm, but i feel the need to upgrade.
My current system is the following:
Intel i5 2500 @3.3Ghz
8GB DDR3 1333Hz
Radeon 6850 1GB GDDR5
I've been looking at both the Dell U24 and the U27 ranges as Dell has been so good in the past, but the new U2713 has been getting some mixed reviews.
My question is:
Would my system run games comfortably at 2650x1440? If so which 27 inch monitor would be best for me to play computer games and colour edit video on.
If not, I would want to go for a 24 inch at 1080p, and which monitor would be best?
My budget for either is £350-400 but if that is not needed then it can be lower.
The ones i found were:
24 inch - http://www.amazon.co.uk/Dell-Ultrasharp-U2412M-Widescreen-Monitor/dp/B005LNDPPS/ref=sr_1_4?ie=UTF8&qid=1374061722&sr=8-4&keywords=dell+u27
27 inch - http://www.amazon.co.uk/Dell-Ultrasharp-U2713HM-Widescreen-Monitor/dp/B0093IW14I/ref=sr_1_1?ie=UTF8&qid=1374061722&sr=8-1&keywords=dell+u27
Thanks to anyone who can help!
I was reading a lot of materials about 24", and i found 2 monitors that i really can recommend for buying. I will buy one of them myself, in the nearest future: SAMSUNG S24A850DW or HP ZR2440W pluses and minuses for both of them:
1) HP ZR2440W
Pluses:
A rigorous body of practical frosted materials;
Excellent build quality;
High color rendering without adjustment;
Excellent results after calibration and profiling;
Good viewing angles;
High speed matrix (with the OverDrive) without appearance of by eye visible artifacts ;
Relatively low INPUT-lag (21.5 ms);
A very wide range of brightness (34-330 nits) while maintaining a high contrast ratio (~ 1100:1);
The high stability of color temperature with the default settings;
Having all of the most essential of modern digital interfaces (DVI-D, HDMI, DisplayPort);
Good kit;
Ergonomic bracket (tilt, turn, lifting);
Excellent management and organization of the menu (no useless picture modes)
Minuses:
Glow-effect when increasing the brightness of the black field and rapid loss of contrast at diagonal angles of view;
A very high price from the competition;
Simple pseudo eight bit matrix (six bits of A-FRC) with the corresponding gradients instead 8 bit that ZR24W had;
Relatively low uniformity of illumination (especially the average deviation from the center point);
The lower area is problematic when measuring the uniformity of color temperature.
May not satisfy:
The crystalline effect - it is still present (although for me it does not exist if you do not think it exists);
"Small" frequency of Pulse-width-modulation - can be seen only on video, in the future, perhaps, could affect the vision;
Compliance with the standard sRGB at 93.6%;
INPUT-lag (21.5 ms) - only if you're a mega-gamer;
Thick and heavy (everything is relative) body, despite the use of LED backlighting;
Lack of D-Sub connector - I do not consider it a minus for monitors with a resolution of 1920x1080\1200.
2) Samsung S24A850DW
Pluses:
An excellent alternative to IPS monitors;
Rigorous and slim body of frosted materials
Compliance with the standard sRGB color gamut for 94.8%;
The magnificent viewing angles;
Fast matrix without the appearance of artifacts;
A USB-hub with four ports of the third version;
A variety of interfaces to connect (D-Sub, DVI-D, Display Port, Audio-in, Audio-out);
The presence of a light sensor and presence sensor;
A wide range of brightness (70-349 nits) without reducing the contrast ratio (~ 900:1);
Cable-management;
Ability to mount VESA-compatible bracket in two ways;
Very low INPUT-lag - 3.2 ms on average;
Low heat and low power consumption;
Ergonomic bracket;
The lack of visible crystalline effect, PWM and color shift - save up our eyes and nerves;
Adequate competitive price.
Minuses:
Poor quality material in the main body sections;
Poor centering of the panel, backlash, swinging.
Very large bracket;
Slightly extended color gamut (more than most IPS);
Problems with the uniformity of illumination;
A large number of useless modes and other settings (Response Time, Gamma Mode).
May not satisfy:
Standard Glow-effect without the appearance of a blue-violet tint shown by IPS displays;
Not very convenient control (especially in low light)
No i didn't. I used russian-speaking sources, cause I'm from Ukraine.
Hmm, there is review for 27" Samsung, he might differ a lot from he's smaller brother.
Still i wrote it for people, that want to read only conclusions, and i hope, i picked good monitors :) And this links are good for broader information and pictures!
I've read about that "dark horse", i can figure out such conclusions:
Pluses:
Rigorous design and high quality materials;
Comfortable and functional control;
Two user mode (User 1 and 2) configurable for fast switching;
Factory calibration (claimed figures are broadly consistent with the measured);
Correspondence the standard sRGB color gamut by 94.9% (in Standard mode and sRGB);
Stable and high 1100:1 contrast ratio ~;
A variety of interfaces to connect video sources and peripherals;
Supports USB 3.0 standard by the USB-hub with four outputs;
Fast matrix with the ability to adjust the acceleration (six steps);
Wide opportunities of ergonomics;
Compatible with VESA-mounting brackets;
The availability of PiP / PbP;
Great delivery set;
Decent uniformity of color temperature;
Function QuickFit, the usefulness of which can be a long debate;
Minuses:
High minimum brightness (~ 100 nits) to work in the dark with a standard contrast (to be reduced to about 800:1 - not a big deal);
The original color accuracy below some 23-inch e-IPS monitors;
Worsening picture modes as Scenery and Theater;
Witless and useless function of 6-axis Color Adjustment (if the producers were not able to properly adjust the mode sRGB, then how a simple user should do it without any devices to check the result);
heavy body as for LED monitor;
Problems with uniformity of illumination on a dark background - clearly visible large lightening areas with a predominance of weak parasitic hue (probably depends on the specimen).
May not satisfy:
Average INPUT-lag of 21.1 ms;
Pulse-width modulation frequency about 200 Hz;
Frosted matrix and related crystal effect;
The absence of a lining cables system;
Standard for IPS matrices Glow-effect without the appearance of a blue-violet hue.
I can place some images for it:
The speed of the matrix and the INPUT-lag
The viewing angles and Glow-effect
http://www.youtube.com/watch?feature=player_embedded&v=qupnVHYw_UA
uniform illumination of the monitor
on white background
diffrent exposure on black background
crystall effect
PWM
eight bands at shutter speeds of 1/25 seconds
those uniformity patches mean absolutely nothing because each individual display is different and has it's own "fingerprint", if you will.
for the absolute best image quality, you must have the display professionally calibrated with a spectrophotometer - whichever one the OP decides on
Hi - some food for thought: I look at user satisfaction when the
sample is high enough. Here's two being recommended and
how they fared (by users) at Newegg in the US.
The Dell U2412 - 90% of users (230 of 255) rated it 4 or 5 out of 5,
truly outstanding.
The Asus p248q - 62% of users (70 of 112) rated it 4 or 5 out of 5.
More concerning - 31 users(27%) rated it below average.
While the Asus is no doubt a worthy choice, there seems to be a
significant QC issues at a minimum.
Think twice.
it shows, that some panels have some troubles, and you need to check it, read more reviews and stuff like that.
I'm in two minds about this. What Dingo says is correct - unfortunately these panels don't all come off the production line the same. Also, these panels aren't even made by Dell or ASUS - all IPS panels are manufactured by LG and then sold to Dell, ASUS etc. So QC issues SHOULD affect all manufacturers equally. That being said, a lot of ASUS monitor reviews do seem to flag up uniformity problems. I'd say the Dell is a solid choice, though back in March of this year, lots of people were complaining about white balance issues on the Dell U2312HMs. I don't think that's Dell's fault because again, it's LG manufacturing these panels.
Tricky one though. Clearly QC standards in general in the industry are lacking. I'm willing to bet that if you bought an Eizo or a LaCie there's about 0% chance of getting even the tiniest defect. They probably thoroughly test all panels they buy. But that's one of the reasons they cost so much!
nah, even NECs panels that cost more than 1.5k$ have some defects.
I worked about a week in front of one PA241W, and the main disappointment for me was noise that 1000$ monitor was producing when brightness was blow 350 nit. It gave me headaches :pfff:
And still, glow effect was present.
I was using an old HP ZR24w, but had to relocate, and gonna buy Samsung I mentioned before. My budget placed me up to this panel.
As any monitor it has some weak sides. This is one of them. Without OD he is not so fast. Switching it on nearly eliminates all the trails, still some artifacts appears, BUT you will find them only if you are looking for them, they are not so bad.
Yeah that's been my experience too. I've never seen a monitor where I can't see the trails if I look for them, but it's been a very long time since I've used a monitor where it was a real problem. Most monitors of the past three years seem amply responsive to me.
