That PSU should have a 7 year warranty so you might be able to get a warranty replacement. If not it is best to just get a new PSU instead of trying to fix the cable.Hello my Corsair tx650w 80 gold has broken. 2 cables on the header the small metallic header are wide open than before.
Can a electrician change the whole 24 cable pin or should I replace the whole PSU?
I have it for 5 years
What is the PSU?is it safe if i play games with a 450w non brand psu?
To answer that, we need the complete specs for the rest of your system (make/model of ALL installed components).is it safe if i play games with a 450w non brand psu?
this one.. like a non brand https://www.plaisio.gr/anavathmisi-...ika/turbo-x-psu-value-ii-series-450-w_1903950What is the PSU?
2600 ryzen 5 cpuTo answer that, we need the complete specs for the rest of your system (make/model of ALL installed components).
That is a very low quality PSU and shouldn't be used in any system. It isn't even a 450W PSU as the max wattage on the 12V rails is 360W. It is also based on a platform that is at least 10 years old.this one.. like a non brand https://www.plaisio.gr/anavathmisi-...ika/turbo-x-psu-value-ii-series-450-w_1903950
From those the only one that can be recommended is the Be Quiet System Power 9. The System Power 10 is one of worst branded PSU available.which one is better ?
1. Be Quiet System Power 10 (BN328) - Full Wired - 650W - ATX - 80 Plus Bronze - Black
2. White Shark GPSU-B600S (COLONEL-2) - 600W - 80+ Bronze - Full Modular
3. Be Quiet System Power 9 600W CM Semi-Modular
which one other do you recommendThat is a very low quality PSU and shouldn't be used in any system. It isn't even a 450W PSU as the max wattage on the 12V rails is 360W. It is also based on a platform that is at least 10 years old.
That Corsair is a very good PSU. Is that PSU less than 7 years old? If so you might be able to get a warranty replacement from Corsair as it has a 7 year warranty.my previous psu was
Corsair TX-M Series TX650M 650W Semi Modular 80 Plus Gold
but suddently something about the 24 pin and the connectors failed i dont know how..
From the ones in which you gave only the System Power 9 is recommended.which one other do you recommend
again my specs are.
2600 ryzen 5 cpu
b450 tomahawk max mobo
rx 570 4gb gpu
lg ultrawide 29 inch monitor
1 ssd
2 hdd
2 x 8gb corsair ram 3200 mhz
in the future i might upgrade gpu or cpu , do i need 550w or 650w psu?
You think that i should I get the same again?That Corsair is a very good PSU. Is that PSU less than 7 years old? If so you might be able to get a warranty replacement from Corsair as it has a 7 year warranty.
PCPartPicker Part ListYou think that i should I get the same again?
There is not warranty now because I remove the warranty stickers to open it and check whether it doesn't get power.
I have in my possession for 5 years.
Anyway.
That Be Quite it's 500w only tho
Shouldn't I get a 600w+ ?
I tried many watt calculators and everyone reported back that I should use a PSU over 550w.
Even if I upgrade CPU in 2 years for example I might need another PSU
So should I choose another?
Could you suggest any one other for about 60-70$
Not available in my country.PCPartPicker Part List
Power Supply: NZXT C (2019) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($69.98 @ Amazon)
Total: $69.98
Generated by PCPartPicker 2024-03-22 20:15 EDT-0400
These series are too expensive for me..CX is below TX, i would choose RXm.
You mean that 600w is enough? I don't get you :/Man just save up a little more. It's not going to be that much more. Psu is blood for the pc, don't skimp on it. Out of sight out of mind i know.. it don't look pretty, it's not how it works and the power supply is the most important part.
