24-pin connector wont fit into motherboard
NinjaClam
4
This is my first PC build that I've done myself and I've ran into a problem
the 24-pin ATX Power connector wont fit all the way into my motherboard slot, and I'm afraid if i push it any more, it might break.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157450
Oh, and I forgot to mention, I plugged it up and everything boots up for maybe half a second then turns off, all lights and fans go on then off for a brief moment.
Any PSU companies you can suggest?
