Just pull it out in a straight motion and you ought to be just fine. Those pins aren't as tiny and obnoxious as those on a CPU socket.oh ok thanks i have never replaced one because i allways build never replace because this is my first build.
I've never seen one of those break.Hi this is a short one but im upgrading my psu tomorrow and im scared i will break one of the 24 pin slot pins taking my old psu out any tips that will stop me getting scared.
oh ok thanks i have never replaced one because i allways build never replace because this is my first build.I've never seen one of those break.
oh okJust pull it out in a straight motion and you ought to be just fine. Those pins aren't as tiny and obnoxious as those on a CPU socket.
can i wiggel it a little to help make it a bit more loose and i also have troubel pressing the latch.Just pull it out in a straight motion and you ought to be just fine. Those pins aren't as tiny and obnoxious as those on a CPU socket.
