C CLocke18 Honorable Jul 30, 2013 5 0 10,510 Jul 30, 2013 #1 I've tried pushing it in and it just simply won't hook into the motherboard. I can't start up the computer and would really like to have this fixed. I'm using the Corsair CX 500 PSU and z87-a motherboard.
abgaut Honorable Dec 27, 2012 140 0 10,710 Jul 30, 2013 #2 Make sure you are hooking it in the right direction until you hear a click. It takes a little amount of force in case of a new build. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jul 30, 2013 #3 Do you have the clip lined up, to pop over the tab. Upvote 0 Downvote
C CLocke18 Honorable Jul 30, 2013 5 0 10,510 Jul 30, 2013 #4 Everything is going in right until it's almost clicked in, then it just refuses to go in anymore. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jul 30, 2013 #5 Try to pull the clip up a little as you slide it over the tab. Upvote 0 Downvote
C CLocke18 Honorable Jul 30, 2013 5 0 10,510 Jul 30, 2013 #6 It doesn't get the point where I can make it over the tab though Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jul 30, 2013 #7 Must be an issue with the connection somewhere. Upvote 0 Downvote
C CLocke18 Honorable Jul 30, 2013 5 0 10,510 Jul 30, 2013 #8 Must be an issue with the connection somewhere. How can I fix this? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jul 30, 2013 #9 Look at both connections is anything bent . or looked crushed. Upvote 0 Downvote
C CLocke18 Honorable Jul 30, 2013 5 0 10,510 Jul 30, 2013 #10 Look at both connections is anything bent . or looked crushed. Everything looks to be fine. Upvote 0 Downvote
