2400mhz supported mobo and 2133 supported cpu will 2400mhz Ram will work at 2400mhz??
lathipaladins
12
This is a bit tricky situation .iam hoping to buy ddr 4 G skill 2400mhz ripjaws 8Gb kit. My motherboard supports up to 2400mhz but my i3 6100 only supports up to 2133mhz .so my 2400mhz Ram will work on 2133 or 2400 ?
Thanks for all the answers guys
"* Due to Intel® chipset limitation, DDR4 2400MHz memory frequency is only supported by 7th Generation Intel® processors. Higher memory modules will run at the maximum transfer rate of DDR4 2400MHz.
** Due to Intel® chipset limitation, DDR4 2133MHz and higher memory modules on 6th Generation Intel® processors will run at the maximum transfer rate of DDR4 2133MHz."
Yours i3 6100 is 6th gen
