Question 240hz monitor help!!
Apr 4, 2020
hello,
so I just build my first gaming pc here are my specs
AMD Ryzen 7 3700X
Nvidia RTX 2070S (Super)
WDC WDS200T2B0B-00YS70 2TB
Corsair CMW16GX4M2A2666C16 2x8GB
Asus ROG Strix B450-F Gaming MB
I currently am running a ViewSonic 27Inch Curved 144hz Gaming Monitor, while playing call of duty i feel like the quality of the picture could be better, also coming from xbox x 4k idk if that has something to do with it, but would me getting a better monitor help at all, i messed with the ingame setting to try to make it little less blurry in distances but not really the best, any advice would be much aprpreciated
Wikingking
Commendable
Nov 11, 2019
33
In the title you write 240Hz but in your description it says 144Hz. However I can't see how is this a monitor issue. What is your framerate? What is the monitor refresh rate? Do you have V-sync on in the game's settings?
How is it blurry exactly?
Apr 4, 2020
my fps in came bounces around 100-144, I turned of v sync in game, and things are just kinda dusty not the clearest
