F Faded247 Feb 23, 2019 5 0 10 Feb 23, 2019 #1 So I just bought a Acer 27" 240hz gaming monitor. Its connected to my new P.C through a Display Port. However no matter what settings I mess with it seems to be stuck at 60 Hertz. Any ideas on what I can do to fix it?
Solution X X XxDarkMario20xX Feb 23, 2019 Try going onto the monitor settings to change the refresh rate and check nvida control panel to see if the settings not capped onto 60.
X XxDarkMario20xX Distinguished Feb 3, 2016 1,821 282 20,940 Feb 23, 2019 Solution #2 Try going onto the monitor settings to change the refresh rate and check nvida control panel to see if the settings not capped onto 60. Reactions: Faded247 Upvote 0 Downvote Solution
J_E_D_70 Splendid Mar 21, 2012 7,291 59 30,290 Feb 23, 2019 #3 Double check you’re plugged into the gpu not the motherboard. Upvote 0 Downvote
boju Titan Ambassador Jul 7, 2008 21,626 2,505 88,390 Feb 23, 2019 #5 What was the issue? Upvote 0 Downvote
