[SOLVED] 240mm Water Cooler
ioannis2015v
171
6
4,695
Hi, I want to buy a water cooler and I would like to ask if it will fit my case. It's the ml240l rgb (or ml240r rgb, I will think of it) which has 2 120mm fans, but the radiator's dimension is 277mm and not 240 (and of other too). The case can take 240mm radiator in the top (Mastercase h500). So will it fit? Is ml240l rgb considered a 240mm water cooler?
Yes the radiator will go in place of the top fans. It has two fans attached to it already.
It may be sound funny but I am confused about it. If I place a radiator (eg. Ml240l rgb) in the top of this pc case, will I be able to add an extra fan as a chasis on the top or the water cooler don't let it?
