[SOLVED] 24GB slower than 16GB
simmyx
358
17
10,695
Tried 2x 8GB and 2x4gb so total 24gb and I was getting less fps when gaming than 16gb ( 2x8gb ) any idea why ?
All the ram is same speed, same model etc
How much less fps?
What is your processor?
Mismatched ram always has possible problems.
Ram is sold in kits for a reason.
A motherboard must manage all the ram using the same specs of voltage, cas and speed.
The internal workings are designed for the capacity of the kit.
Ram from the same vendor and part number can be made up of differing manufacturing components over time.
Some motherboards, can be very sensitive to this.
This is more difficult when more sticks are involved.
Is the ram capacity evenly divided on both channels.
If not, part will be operating in slower single channel mode.
Possibly, the motherboard needed to lower the speed to get all 4 sticks to work.
It would be worthwhile to
Run memtest86+
It boots from a...
How much less fps?
Run memtest86+
It boots from a usb stick and does not use windows.
You can download the free edition here:
If you can run a full pass with NO errors, your ram should be ok.
Running several more passes will sometimes uncover an issue, but it takes more time.
Probably not worth it unless you really suspect a ram issue.
