Lately my computer has been shutting down randomly when either gaming, watching youtube videos or just surfing the web. When this happens both my screens go black and the fans on the GPU ramp up to 100%. to get the computer working again i have to manually restart it by holding in the on/off button and powering up the computer again. this usually happens from time to time, but yesterday it happened twice in a row, and i was unable to fully boot the computer back up after the second time. Both my GPU and CPU were running at stock speeds at the time, and the temperatures never exceed 70 °C on either one while gaming. I decided to check my cables to see if there were any loose connections causing this. When i went to pull out my 24pin cable i noticed it was pretty difficult to remove from the motherboard. This was because 2 of the pins on the 24pin cable had melted into the socket on the motherboard. At the time i was using an extension cable instead of the original cable that came with my PSU. My CPU is also delidded and was overclocked to 5ghz at 1.34v i believe. It ran flawlessly for a few months before i decided to go back to stock settings as i had no use for the extra speed at the time and wanted to avoid straining the CPU unnecessarily. I am wondering if this problem could have happened because of the delid or the extension cable, or if it is a problem with either my PSU or motherboard. There is no damage on the outside of the PSU as far as i can see.
My specs are:
- Asus Geforce GTX 1080ti strix 11gb
- i7700k
- Corsair Vengeance 16 GB DDR4 2400 MHz
- NZXT Kraken x62 280mm
- Asus Rog Strix z270-f gaming
- EVGA supernova 750 G3
I have attached pictures of the cable and the socket. Any help is appreciated as i do not know what my next step should be.
MB: https://imgur.com/a/xhzZgUq
Cable: https://imgur.com/a/0UvFSeZ
My specs are:
- i7700k
