Hello,
I want to get a new video card, but I'm worried that it might fry my PSU. Here are the specs for the card I want...
Model
Brand
DIAMOND
Model
BV750
Form Factor
Low Profile
Interface
Interface
PCI Express 3.0 x16
Chipset
Chipset Manufacturer
AMD
GPU
Radeon HD 7750
Core Clock
800MHz
Stream Processors
512 Stream Processors
Memory
Effective Memory Clock
1125 MHz
Memory Size
1GB
Memory Interface
128-bit
Memory Type
GDDR5
3D API
DirectX
DirectX 11.1
OpenGL
OpenGL 4.1
Ports
DisplayPort
1 x Mini DisplayPort
DVI
2 x DVI
General
RAMDAC
400 MHz
Max Resolution
4096 x 2160 (DisplayPort)
Eyefinity Support
Yes
CrossFireX Support
Yes
Cooler
With Fan
Slot Width
Single Slot
System Requirements
400W or greater power supply
Power Connector
6 Pin
Dual-Link DVI Supported
Yes
Card Dimensions
Height:2.8" x Length:6.8" x Thickness:1.3"
And here are the specs for the computer I have...
General Spec
Brand
ASUS
Model
P8H61E (BP6320-I53470163B )
Type
Business Desktops & Workstations
Usage
Business
Processor
Intel Core i5-3470 3.2GHz
Processor Main Features
64 bit Quad-Core Processor
Cache Per Processor
6MB L3 Cache
Memory
8GB DDR3 1333
Hard Drive
1TB 7200RPM
Optical Drive 1
Tray-in Supermulti DVD RW 24X
Graphics
Intel HD Graphics 2500
Ethernet
Gigabit Ethernet
Power Supply
250W (80 Plus Bronze)
Operating System
Windows 7 Professional
Software Included
Windows 7 Professional with Windows 8 Pro CD
PC-cillin Trial Version
Office 2010 Starter or Office trial
Nero Essentials (for ODD sku only)
ASUS AI Suite II
ASUS Update
ASUS Q-fan II
ASUS EPU
F9 One Key Restore
ASUS WebStorage
ASUS Secure Delete
ASUS AI Recovery
Motherboard
Chipset
Intel H61
CPU
CPU Type
Intel Core i5
CPU Speed
3470(3.20GHz)
L3 Cache Per CPU
6MB
CPU Socket Type
LGA 1155
CPU Main Features
Max Turbo Frequency 3.6 GHz
Graphics
GPU/VPU Type
Graphics Interface
Integrated video
Memory
Memory Capacity
8GB DDR3
Memory Speed
DDR3 1333
Memory Spec
8GB x 1
Memory Slot (Total)
Memory Slot (Available)
Hard Drive
HDD Capacity
1TB
HDD RPM
7200rpm
Optical Drive
Optical Drive Type
DVD Super Multi
Optical Drive Spec
Audio
Audio Channels
6 channels
Audio Features
VIA VT1705, High-Definition Audio
Communications
LAN Speed
Intel 82579V GB LAN
Support Wake On Lan function
Front Panel Ports
Front USB
4 x USB 2.0
Front Audio Ports
Back Panel Ports
COM
PS/2
Video Ports
1 VGA, 1 DVI
Rear USB
4 x USB 2.0
RJ45
1 port
Rear Audio Ports
3 ports
Expansion
PCI Slots (Available/Total)
1 x PCI
1 x PCI-e x 16
2 x PCI-e x 1
Mouse
Mouse Type
USB/PS2 Mouse
Keyboard
Keyboard Type
USB/PS2 Keyboard
Physical Spec
Dimensions
15.75" x 12.99" x 3.78"
Thanks!
Model
Brand
DIAMOND
Model
BV750
Form Factor
Low Profile
Interface
Interface
PCI Express 3.0 x16
Chipset
AMD
GPU
Radeon HD 7750
Core Clock
800MHz
Stream Processors
Memory
1125 MHz
Memory Size
1GB
Memory Interface
128-bit
Memory Type
GDDR5
3D API
DirectX
DirectX 11.1
OpenGL
OpenGL 4.1
Ports
DisplayPort
DVI
2 x DVI
General
RAMDAC
400 MHz
Max Resolution
Eyefinity Support
Yes
CrossFireX Support
Yes
Cooler
With Fan
Slot Width
Single Slot
System Requirements
Power Connector
6 Pin
Yes
Card Dimensions
General Spec
Brand
ASUS
Model
Type
Usage
Business
Processor
Cache Per Processor
6MB L3 Cache
Memory
8GB DDR3 1333
Hard Drive
1TB 7200RPM
Optical Drive 1
Graphics
Ethernet
Gigabit Ethernet
Power Supply
Operating System
Software Included
ASUS AI Suite II
ASUS Update
ASUS Q-fan II
ASUS EPU
F9 One Key Restore
ASUS WebStorage
ASUS Secure Delete
ASUS AI Recovery
Motherboard
Chipset
Intel H61
CPU
CPU Type
Intel Core i5
CPU Speed
3470(3.20GHz)
L3 Cache Per CPU
6MB
CPU Socket Type
LGA 1155
CPU Main Features
Graphics
GPU/VPU Type
Graphics Interface
Integrated video
Memory
Memory Capacity
8GB DDR3
Memory Speed
DDR3 1333
Memory Spec
8GB x 1
Memory Slot (Total)
Hard Drive
HDD Capacity
1TB
HDD RPM
7200rpm
Optical Drive
Optical Drive Type
DVD Super Multi
Optical Drive Spec
Audio
Audio Channels
6 channels
Audio Features
Communications
LAN Speed
Intel 82579V GB LAN
Front Panel Ports
Front USB
4 x USB 2.0
Front Audio Ports
Back Panel Ports
COM
PS/2
Video Ports
1 VGA, 1 DVI
Rear USB
4 x USB 2.0
RJ45
1 port
Rear Audio Ports
3 ports
Expansion
1 x PCI
1 x PCI-e x 16
2 x PCI-e x 1
Mouse
Mouse Type
USB/PS2 Mouse
Keyboard
Keyboard Type
USB/PS2 Keyboard
Physical Spec
Dimensions
Thanks!
