hi there.
well i got the following system:
abit nf7-s v2.0
amd barton 2500+(multiplier locked to 11)
gigabyte radeon 9600 pro ultra
2x256 mb ram kingston valueram ddr 400
cooler zallman cnps6000+ full Cu
i've trie to overclok the system and the only stable config i've got is
2103 mhz(190 x 11) temp 35-43(C)
ram sync at 380 mhz
if i raise the bus fq more than that the system doesn't boot
then, i've modified the cpu voltage to 1.7(from 1.65) and it boots, but after 1-2 minutes of running hot cpu tester it reboots. i've tried ram voltage from 2.6 to 2.7 and the result it's the same. i want to obtain 3200+ but it won't work. how do i do it(i think is from ram but i don't know). the config for ram i've tried are 9-3-3-3 and 8-3-3-3. so i guess it's all about voltages. please help
thanks
abit nf7-s v2.0
ram sync at 380 mhz
thanks
