2500K Overclocked Usage and Temperature
RolandDeschain19
18
So I have overclocked my 2500K to 4.2 GHz and in games like GTA V my CPU usage is around 90 %, sometimes 100 % but my temperature never goes over 55 °C (I have the 212 EVO cooler). Is that normal, should I be worried about usage or temperature?
if your CPU is keeping to 55 °C under that kind of a lode then you have quite a good one. you could likely push it to 4.6GHz with out an issue. (whats the voltage your using?)
so long as your under 80 °C i see nothing to be worried about. i recommend running something like Prim95 to get a better sense of your upper temperature range than a game though.
