2500k with geforce gtx 680 or 3570k with geforce 560 ti
rowski
11
Hi, ive been looking for a computer to deal with gaming 100% of the time. I'm wondering which of these builds is better. I've looked at the other topics about these processors but was not sure about if the information applies to my situation in only wanting gaming power.
i5 2500k with a geforce gtx 680 or
i5 3570k with a geforce gtx 560 ti which is 200 pound cheaper.
I know the graphics might be worse on the 560 ti but I'm wondering how much the processor makes up for it. I've never overclocked so I wont understand any advice about that. --though i might look into it at some point.
2500k is a Z68AP-D3 motherboard- didnt say a power supply on the website- worrying. and Asus P8Z77-V LX Motherboard with 750 Watt Branded Power Supply. hmm, wonder how upgradable those motherboards are.
i7 3570K + eVGA 680 + MSI Z77-G65 (or Asus Sabertooth Z77). Throw-in a nice after market cooler. Yes, IB suffers from heat issues if you over clock. But, you should be fine as long as you do not overstep the line. General opinion is 4.2 - 4.5 (max) would keep the volts under control. As long as the volts do not exceed Intel's limit, you would be fine.
Pay $20, get your i5 3570K protected with Intel's amazing tuning protection plan
http://click.intel.com/tuningplan/.
I;m confused.com the difference in price on the cpu's are about £10-20 and on the gpu's are like £200?? Why not get the 680 and the 3570??
the 680 is a waste of money, when you look at the 670's performance.. its so close as to be negligible but costs way way less.
the 2600k is also a better choice for general use... some newer games will benefit from hyperthreading. yes most games wont use it but its better to have it and not need it than need it and not have it...
it will oc just as well and perform pretty much identically as the 3 series ivy because it can oc better and that little extra will close down any gap that there is performance wise...
so i would say neither...
get the 2600k and a gtx 670. overall your looking at pretty much the same performance but for less money overall...
No point in getting i7 2600K. If you really do not want IB, i7 2500K. Period.
However, the choice should be i7 3570K, GTX 670 (if not GTX 680) plus Intel's fine tune plan protection for $20.
http://pcpartpicker.com/p/8PFM
i found out that the same store for 50 pound more do an extra terror byte hard drive and have the gtx 680 with the i5 3570k. but if the 2500k is not much different to the 3570k then all im getting is the expanded harddrive right?
That combo sounds like a pretty good deal, actually. Which 1TB HDD is it?
In the olden days a bigger hard drive would add to the performance of the computer. Is this still true? will a TB extra increase performance?
Hmm, that's strange. I really can't tell you if the 2TB drive is any faster, then. Even if it was, it wouldn't be MUCH faster, but it would be very helpful to know what RPM both drives are.
In any case, that deal sound pretty good, but if it's a slow drive, it's not so good. No info; no way of knowing.
