250gig external firewire drive problems
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I'm trying to install a 250gig maxtor external firewire drive (via PYRO
drive kit)
and its only seeing 137gig max...
Are there size limitations via firewire??????
thanks!!
_______________________________________________________________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
<><><><><><><> The Worlds Uncensored News Source <><><><><><><><>
G
Guest
Guest
">>BadBoy" <zzz@nospammers.com> wrote in message
news:4095b60a$1_3@news4.uncensored-news.com...
> drive kit)
> thanks!!
No limitations by firewire, but the kit itself probably has the limitation.
The answer is to buy another EIDE-->USB adapter that advertises the maximum
size you need.
G
Guest
Guest
">>BadBoy" <zzz@nospammers.com> wrote in message news:<4095b60a$1_3@news4.uncensored-news.com>...
> drive kit) and its only seeing 137gig max...
Firewire does not have a 137GB drive limitation. But some ATA to
Firewire bridges do have a 137GB limitation. I know that current
ADS Pyro drive enclosures support large drives--I've got one here in which
I had a 200GB drive. I think I bought the enclosure late last year.
igor
112
> thanks!!
I'm 99% sure it's a limitation of you operating system. What are you using?
G
Guest
Guest
>drive kit)
Not Firewire as such, but there may be in other parts of the system.
Partition the drive.
G
Guest
Guest
Hey guys!
I want to thank everyone for all their KWIK replies!
The problem was with the drive kit... I was using an older ADS PYRO kit...
and it just wouldnt see pass 137 gig!!!
I switched the kit to a newer drive kit that I had... plugged it in...
and immediately winXP saw the 250gig drive...
Just had to partition and format it via Drive Management...
thanks again!!!
BRENT in Houston
> drive kit)
> thanks!!
___
