I have a http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017, I want to OC it. I want to make sure that I can dispense the heat well enough. I ordered http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
but I have this case http://www.newegg.com/Product/Product.aspx?Item=N82E16811124121 and the 250 mm fan sits right over the mobo. That heat sink is too big if I remove the fan it will fit. I have http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134 on the CPU right now and I idol at 30-33C and at load 39-43C. MY case Temp sits at 16-18C
I want to OC to at least 3.0(to start i will go higher later on.) so im guessing I might go up 3 or 4C. I have 2 other fans both http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054 one in the rear (reversed so it’s blowing air in onto the Heat sink.) And one in the front blowing air in.
So here is my question.
Does the 250mm fan make a difference? Is it a good idea to remove it?
Is the http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003 worth it over the http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134 for OCing?
thxs
thxs
