2 2ms Distinguished Feb 1, 2010 38 1 18,535 0 Jul 2, 2022 #1 I am thinking of buying a Threadripper 5995X Lenovo P620 with at least 256GB RAM. Could anyone recommend a memory kit for such a machine? It’s not easy to find such large memory kits.
0 Lutfij Titan Moderator Oct 7, 2009 44,244 2,849 140,440 8,363 Jul 2, 2022 #2 If you have the funds for it, here you go: https://www.amazon.com/Lenovo-64GB-DDR4-3200MHZ-RDIMM/dp/B08PT897V4
0 E egda23 Estimable Jun 14, 2020 1,384 256 3,190 164 Jul 2, 2022 #3 This one https://www.amazon.de/-/nl/dp/B08763QH8S/ref=sr_1_12?__mk_nl_NL=ÅMÅŽÕÑ&crid=1L055X48U0PIU&keywords=Crucial+64gb&qid=1656769613&s=computers&sprefix=crucial+64gb,computers,99&sr=1-12 is also indicated as compatible on Crucial memory compatible page https://www.crucial.com/compatible-upgrade-for/lenovo/thinkstation-p620
0 2 2ms Distinguished Feb 1, 2010 38 1 18,535 0 Jul 2, 2022 #4 Those are single DIMs and damn expensive. I guess there is no need to buy them in matching kits? Looks like 256 may be the only thing I can afford.
0 USAFRet Titan Moderator Mar 16, 2013 156,189 11,690 176,090 24,278 Jul 2, 2022 #5 2ms said: Those are single DIMs and damn expensive. I guess there is no need to buy them in matching kits? Looks like 256 may be the only thing I can afford. Click to expand... Yes, a 'set' is MUCH preferable to individuals. At s56GB, all I'm seeing is ECC, or 8x32GB.
