Currently have an IPS LG 27850GL which is about 5 years old and working fine, but I'd like to check out what a higher contrast screen has to offer for gaming. Exploring options, I am semi familiar with the various display techs available but cant claim to be an expert. Please correct or advise if theres something I'm not understanding or missing. Looking to make a short list of potential models to compare for myself.
The headlines
- Budget of €800 or less, would rather spend less if possible.
- Will buy probably later in the year, possibly around Black Friday.
- I'm in Europe (Finland). Will either buy locally or from Germany if prices are better.
- Running an RTX 4070 with a Ryzen 5800X3D.
- OLED Screen. Would consider VA or Mini LED, but I would like something thats a meaningful IQ upgrade over what I have without noticeable smearing in games etc.
- 2560x1440
- At least Freesync Premium or Gsync. I switch GPU brands so it needs to work with all GPU types.
- No brand preference. Not a big fan of 'gamer' style but willing to be flexible if the screen is great.
- 27 inch, would consider 32 if theres a really good one.
- Anything 120Hz plus is fine, more is a bonus but not required as I'm happy with VRR at 80hz plus, and will lower settings to maintain that frame rate.
- If it matters I play almost everything, FPS, IMMSIM, Soulslikes, CRPG, 4X Strategy, etc but almost all single player.
What Ive found so far:
I've checked out some Rtings articles and a lot they are recommending is at 4K for gaming and I dont want to go there yet.
https://www.rtings.com/monitor/reviews/msi/mpg-271qrx-qd-oled
https://www.rtings.com/monitor/reviews/gigabyte/aorus-fo27q3
These 2 are over budget.
https://www.rtings.com/monitor/reviews/asus/rog-strix-oled-xg27acdng
This one is bang on budget but I'm not big on the ROG aesthetic. If its the only option I'll consider it.
Display Ninja recommends another Asus except its well over budget and the same over budget MSI model as above.
https://www.displayninja.com/best-oled-monitor/#PG27AQDP
Finally
Am I dreaming about finding multiple OLED models to compare at this budget level curently? Or are there some worthwhile options I'm missing the bigger sites arent recommending? If theres anyone out there with good quality options for under €800, or any upcoming releases that might be more suitable it would be much appreciated! TIA.
The headlines
- 2560x1440
Finally
