T Tim F Distinguished Dec 12, 2009 28 1 18,535 Feb 7, 2021 #1 Any benefit to going over 2560x1440 on a 27 inch monitor? Thanks, Tim
Solution Fiorezy Feb 9, 2021 Better for productivity but lower image quality, also don't go with higher than 27" if you sit close to the monitor
Dj0gany Distinguished Apr 5, 2020 5,825 1,328 19,690 Feb 7, 2021 #2 Depends on what,gaming no if you more fps,but if you want looks go for it. Upvote 0 Downvote
Fiorezy Notable Jul 3, 2020 376 86 890 Feb 9, 2021 Solution #3 Better for productivity but lower image quality, also don't go with higher than 27" if you sit close to the monitor Upvote 0 Downvote Solution
S sizzling Titan Oct 18, 2006 27,226 3,301 112,240 Feb 9, 2021 #4 Fiorezy said: Better for productivity but lower image quality, also don't go with higher than 27" if you sit close to the monitor Click to expand... I read it that the question was a higher resolution at 27”? Upvote 0 Downvote
