[SOLVED] 27" 1080p monitor for programming/ web browsing
Jan 17, 2020
8
Hi i am currently using 720p old monitor i want to upgrade to a new one should i buy 24" 1080p monitor or 27" 1080p, i am on tight budget so i cannot afford expensive monitor.
i would go 24 1080p as it has better PPI and smoother text. On the 27", at 1080, the UI is hilariously massive and the pixels can be apparent depending on your vision. 1440p seems to be the sweet spot for 27"
