Would like to know people's thoughts. I sit about 1.5 to 3 feet from monitor
Would 4K at that size be noticeably better image quality over 1440P.
I have a GeForce RTX 4090 with a Core i9 13900K and 32GB DDR5 RAM I am about to put to work. Would it be able to keep up easily at 4K put out 90 to 120 FPS with all settings maxed out including using MSAA or SMAA 2X, 4X or even 8X in latest AAA games?
Would 1440P it be way overkill and give me 150 to 200 FPS or even more which is unnecessary unless you play like the most ESPorts competitive games which I generally do not?
I already have a 1440P but wondering if it is worth at that screen size of 27-28 inch upgrading to 4K 144Hz monitor to put to use with an RTX 4090 like is the image quality going to be noticeably better at 27-28 inch screen size?
https://www.thetechtoys.com/best-monitor-for-rtx-4090/#:~:text=If you want the smoothest,but comparatively gives low FPS.
They seem to suggest even with RTX 4090 which many feel is overkill for anything but 4K (Heck some even say 3090/3090 Ti were, but we all know it was not for 1440P unless you were ok with like 50-60 FPS maxed out in games or did not turn all setting to ultra in games)
Though it doe seem 90 to 120 FPS is clearly smoother and much so even for non super competitive online player games over 50 to 70 FPS, is 150 to 200 FPS or more going to give better experience in games like Read Dead Redemption, Cyber Punk and such single player?
Not concerned about small font at 100% display in Windows desktop and word as I will just make it bigger using Windows display settings anyways.
