Hello! I'm new to a lot of computer stuff so bear with me. I have a very expensive build that I have been putting together with a friend for awhile now. I have a basic understanding of parts and what I prefer but I will admit my friend helped me put everything together in the end. my build is as follows:
Currently i wanted to upgrade my storage 2TBs is not very much, especially using blender. I was going to upgrade to anywhere from 8-14 TBs in an HDD but have not had the chance as a pretty severe problem ( from what i understand ) has appeared. My CPU under load will reach 65-75 degrees Celsius very easily and it makes me extremely nervous to see it that high. i only have the pre-applied thermal paste on the cpu cooler right now, but i did order some grizzly Cryonaught thermal paste that i am going to replace it with when it arrives. my current setup has 7 x 120mm fans 4 with the computer and 3 with the NZXT cooler. I have it set with 3 fans on the front as intake with the CPU inter cooler directly behind them. I have the 3 NZXT fans mounted on top of the case pushing air out as exhaust, and the final fan on the single open slot on the back pushing air out as exhaust as well. I'm super against Air coolers even though i know they have been proven to work better, they are extremely ugly and i have specifically picked some of the parts in my build so i can show them off through my glass case. is there a AIO liquid cooler that i could do better with? and i would maybe look into a custom CPU liquid cooling system but i have no clue where to even start. Could i have my fans mounted better? ( i just remembered it should be noted i did take the glass off the front and top of the case so the fans are not suffocating i only have the side panels on ) i just feel like there is so much un-tapped potential with my current build that i am not taking advantage of and I'm praying that I'm not hurting or bottle necking anything. i have built 2 computers prior. one of which was my first gaming rig and much much cheaper and more simple. Any assistance or good tips for any of these parts would be super appreciated. i am completely settled on the 2950x and the lightning Z though so please do not start recommending different parts in those categories thanks! - Sushii ( Steve )
- CPU: AMD 2950x Threadripper
- Mobo: ASUS Rog Zenith Extreme Alpha
- GPU: MSI Lightning Z 2080ti
- Ram: 32GBs ( 4x 8GB ) Corsair Vengence RGB 3600MHz
- PSU: Corsair HX1000i 80+ Platinum
- Cooler: NZXT Kraken X72 360mm AIO liquid
- Memory: Samsung 970 evo 1TB M.2 SSD / 1TB Seagate HDD
- Case: Couger Panzer EVO RGB full tower
