2GB: Corsair (667mhz) or Geil (800mhz)? help needed
Dark_Placebo
185
which one should I buy ? well, the Corsair one is more expensive even if only has 667mhz..
and also, would there be a difference if i buy a Corsair Twin 1 GB (2GB) and Corsair Value Select 1 Gb x 2 (2GB) ?? or basically the same ?
imo I choose the best memory I can afford. And Corsair is an excellent brand, whether you get the XMS2 or the value series. I have seen where certain past models of the Corsair value RAM overclocked excellent.
I am using XMS2 533MHz at 5.5.5.15 spd rated timings, but am running the 100% stable at 9x 334MHz 2.25vlts at timings of 3-3-3-8, far exceeding my expectations.
i agree with RichPLS, i too prefer corsair simply because it's a great ram, stable, oces well, never failed on me yet, so yeah if you're talking about brands, i'd suggest corsair as well.
okay, i also would like to choose corsair...
so.. just get the corsair 667 mhz instead of GEIL 800 mhz ?
does the 667 mhz and 800 mhz make alot of difference ?
actually, i really dont have plans OC, since im not adept or knowledgeable yet.... might be doing some soon.
i would be using E6600.... so... should i just get corsair at 667 ? do i need to setup more things ? or configure ? thnks alot !
Your question has been answered about 3 times now, get the corsair RAM unless you plan to overclock past 375mhz FSB, in which case you would need faster RAM (800).
