flamingxeno
18
I know there are a few other threads like this but I think what I am looking for is a little different. Mainly, I really don't like multimonitor setups at all. I currently have a somewhat aging 2560x1600 monitor that I plan on replacing later this year with 3 1080p miniteurs. I would like to go ahead and build my gaming rig now and just use it with my old monitor until I get the new one.
So what are your suggestions for a $2000 build that would get the best possible performance in games on a single 30 inch 2560 x 1600 monitor? I only care about gaming performance since I use my work laptop for any other applications.
I already have a monitor, mouse, keyboard, so no need to include those.
Thanks for any help and wisdom.
Edit: Here is the breakdown:
I just noticed the guidelines post so here is an easier to read breakdown of what I am looking for:
Approximate Purchase Date: nov 2011
Budget Range: $2000 before rebates
System Usage from Most to Least Important: gaming
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: Ncix (but will accept other websites)
Country of Origin: Canada
Parts Preferences: would like an ssd and the haf 932 but don't feel you have to use them
Overclocking: Probably
SLI or Crossfire: Yes
Monitor Resolution: 1 2560 x 1600/ 3x 1920 x 1080
Additional Comments: N/A
kagebe
47
If you can wait till the end of November, they should be releasing the LGA 2011 and the Sandy Bridge-E. I highly suggest it, since your build is around 2g and you are waiting till November.
