2K monitor with GTX 760
swzeng
151
Hi
So I have a GTX 760 and CPU: I7-4820K LGA 2011, is it worth the upgrade to get a 2k monitor? I play Age of Empire HD a lot and on Voobly it is supported in high resolution. Is the following worth it?
ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms HDMI DVI VGA Eye Care Monitor
I'd personally have no issues with the benq, IPS panel, nice colors, probably needs some set up to look the way you want, but nothing wrong with the price.
got it, but I only play age of empre (assume low requiremnt?) and mostly for work (coding). I thought this card can candle 1440 through DisplayPort according to the official site...no?
Cool, thanks. BTW, any suggestions on the following or other similar? budget around 350....
BenQ GW2765HT" - https://www.amazon.com/BenQ-GW2765HT-27-Inch-2560x1440-Monitor/dp/B00KYCSRSG/ref=pd_ybh_a_6?_encoding=UTF8&psc=1&refRID=G167Q41M5YNTGQ1T17C4
ASUS PB277Q
https://www.amazon.com/ASUS-PB277Q-WQHD-2560x1440-Monitor/dp/B01EN3Z7QQ/ref=pd_ybh_a_6?_encoding=UTF8&psc=1&refRID=2NRBHDPAB1CANF1RNS7T
