2nd build advice (inc. Watercooling)
Zapodidae
8
Hi guys, Making my second build and looking for any advice you may have on the chosed products, specifically the watercooling as this will be my first loop.
I want the build to look great due to the case being full glass.
I will be going for a black/white/purple theme and really just looking for any advice on tweaking parts, and watercooling advice especially such as how many fittings I will need (presuming 2x per watercooled peice? but would like it if someone can confirm) Thanks in advance.
SSD
RAM
Fan x3
PSU
GPU
Case
MoBo
CPU
Cooling loop
Edit: just to add I already have a HDD from my old build so I'm fine for storage.
Everything looks pretty damn good except that the link to the RAM is dead. However I am a bit doubtful towards the BitFenix PSU as it seems really cheap compared to other PSUs that have the same or similar specs.
Thanks - link to the RAM should work now, somehow the html and the link for the fans had mixed in with the one for the RAM and killed the link.
Thanks. I like the white sticks and seeing as Corsair is cheaper and has better timings I will likely go for those!
