2nd Build Help
heavyarms39
41
Hi Everyone,
To start off, I am somewhat dissatisfied with my build that I've had for about a few months now. I'm fairly new to the pc community and I've spent about $800 on my build and now i'm thinking for the future of what I can create/upgrade. I've had problems trying to crossfire this APU with my graphics card and i've been dealing with freezing issues that I cannot seem to fix till this point. I don't play any hardcore games right now just Diablo 2 and counterstrike...possibly Diablo 3/BF3 when it comes out. Just seeing if anyone can recommend any better builds/upgrades that are more towards AMD (Don't recommend bulldozer). In the next year i'd be looking to spend a good 1000-1200 for a medium-high end gaming rig
Thanks in advance for your help
Currently I have:
Asus F1a75-M PRO Mobo $105
AMD a8-3850 Llano Cpu $139
G.Skill 2x2gb 1333 ram $35
Corsair cx600w Psu $50
Antec 300 Case $40
Cooler Master tx3 Heatsink $20
XFX Radeon HD 6670 GPU $80
Acer 21.5'' 19x1080 Res $129
Windows 7 Home Premium 64 Bit $100
Either way
u'd typically go for this
AMD Phenom II X4 955 -114 Or AMD Phenom II X6 1090T - 170
ASUS M5A97 (AM3+) - 95
COOLER MASTER Hyper 212 Plus - 40
G.SKILL Ripjaws X Series 8GB 1600 - 68
GIGABYTE Radeon HD 6950 1GB - 239 or EVGA SuperClocked GeForce GTX 560 Ti (Fermi) 1GB 249
Note: Either card you get will max out your games no problem
OCZ ModXStream Pro 700W - 94
OCZ Vertex 2 120GB - 174
Note: This is optional
COOLER MASTER Storm Scout - 89
Western Digital Caviar Green 2TB -100
LG Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 10X BD-ROM - 86
Note: If your not watching blue-ray's on your PC, This is Optional. You could get a dvd drive for less then 30
Total: 1165 with SSD and BR Drive
Total: 905 w/o optional
I thought you cant crossfire them, however you can run say 1 monitor on your gpu and the other on your apu and they will work together that way
well since u cant go any higher then a 6770, you might as well get a second. I still dont understand why you'd go the APU path but want a mid-high range build.
Because now ur stuck with only the 6770's and cant go higher. Which is a critical factor for gaming .
^It's a 6670** Right now it has all the functions to carry out my tasks
I said i'm also looking to get a new build within the next year or so...ill pass it down to my brother since he'll use a mid range build, but when I built the system I needed a medium range build for about a year so im going to pass it down to him....THEN go higher...you guys arent getting the point I amjust looking for a new build. That's it.
Either way
Perfect, that's an answer I was looking for...Great recommendation I'm liking everything and it fits well in the price range. I'm not familiar with OCZ's products though but i've heard a lot of good things so I would like to try them out...Everything else sounds good.
Thanks again for your help appreciate it.
