2nd Graphics card not detected
Beyers Nel
14
Problem
My PC used to work fine but then exhibited various problems and now does not detect my second graphics card. Any single graphics card in any slot will be detected. If both are in then only the top / primary one will be detected.
Symptoms
The Gfx card fans will always spin up. If the EVGA card is in the second slot while the MSI is in the first then the EVGA fan will spin very loudly.
Before the current problem my PC started crashing randomly. This included BSODs but also the PC stuttering and then freezing. My Gfx cards were not overheating and my PC has been cleaned of fluff and dust.
I'm fairly sure the freezes and BSODs started after I updated to nVidia's 320.18 driver, which possibly conflicted with factory overclocked cards like mine.
I rolled back to 314.07 but the problems continued. Currently I'm running 320.49.
Specifications
Operating System
Microsoft Windows 7 Ultimate 64-bit
CPU
Intel Core i7 920 @ 2.67GHz 40 °C
Bloomfield 45nm Technology
RAM
6.00GB Single-Channel DDR3 @ 534MHz (8-8-8-20)
Motherboard
Manufacturer ASUSTeK Computer INC.
Model Rampage II GENE (LGA1366)
Chipset Vendor Intel
Chipset Model X58
Chipset Revision 12
Southbridge Vendor Intel
Southbridge Model 82801JR (ICH10R)
Southbridge Revision 00
System Temperature 29 °C
BIOS
Brand American Megatrends Inc.
Version 0705
Date 2009/04/09
Graphics
EVGA GTX460 SC
MSI N460GTX cyclone igd5 OC
EDIT: PSU
Vantec iON2+ 600W
Can you tell us what brand of power supply you are using and how many watts it is rated at. And what model number of graphics card`s
And how long you have had your power supply.
Psu`s degrade over the time they are in use and become less stable.
Often blue screens, unexplained shut down`s and hardware not being detected can be a cause of the PSU in the system failing.
I updated the PSU info. I think it's about 2 years old. Swapping the power cables between the Gfx cards doesn't make a difference.
I understand that the Gfx card brand does not make a difference, just that the models need to be the same. I've been running them in SLI for a year without a problem, until recently.
EDIT:
Updated Gfx card info
it could be a driver problem, to make sure it is not, download driver fusion and the latest drivers.
install driver fusion.
uninstall nvidia drivers but do not restart when prompted.
run driver fusion and clean the nvidia drivers then restart.
install latest drivers again.
do this just to make sure its not something with drivers.
if this does not work then it could be the power supply.
Thanks mauller07
I actually already did this exact procedure when I rolled back my drivers. I followed another article for people who wanted to uninstall the 320.18 drivers.
Thanks Unolocogringo
Is there a way for me to test this out first before spending money? Should I disconnect all my unnecessary harddrives to reduce power consumption and test again?
It looks like the cards function according to which power cables are being used after all, and not what slot they are fitted in. I'm going to look into getting a new PSU. If that solves the problem then I'll update the thread
I fitted a new PSU and it seems to have solved the issue with the Gfx card not being detected. I'll have to wait and see if there's still other instabilites, like freezes and BSODs.
