2nd hard drive issue, how do u take ownership???
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
how do u take ownership of a drive u were using on an old computer or add ur
user sid to browse the drive??/ this is a ntfs drive.
G
Guest
Guest
nah that doesnt help. ive got one of those, i formated my master and now i
cant access my slave problems. seems every1 has it but i cant find any actual
answers. i know the files are there coz i used a progam that told me so. i
just cant use it coz when i click on the drive it ask me if i want to format.
i know its a windows problem too as wdc (my hard drive manufacturer) told me
so.
so far all i know is
its a fat32 system and i cant access or see the files on windows xp running
sp 2
G
Guest
Guest
Right click My Computer, Manage, Disk Management. You can assighn a drive
letter there.
"gav05" <gav05@discussions.microsoft.com> wrote in message
news:BD2B18DA-1DD2-494B-ADDB-251019340DAD@microsoft.com...
> ur
G
Guest
Guest
Try booting into Safe Mode, right click on the Drive, click Properties,
then look in Security and take ownership as well as Add your user name
ot the permissions giving yourself full control. Similar to the method
mentioned here:
http://support.microsoft.com/default.aspx?scid=kb;en-us;823306
Nathan McNulty
> so.
> sp 2
G
Guest
Guest
that doesnt work using ur method nathan. u cant get a security tab up on a
hard drive and i cant see any of the folders any way as when i click on the
drive with the left click it ask me if i want to format.
ANY1 got any actual answers??? i will send any one a cheque for 50 aus
dollars if they can as im desperate!!!!
G
Guest
Guest
> add ur user sid to browse the drive?? this is a ntfs drive.
> Properties, then look in Security and take ownership as well as Add
> your user name ot the permissions giving yourself full control.
> Similar to the method mentioned here:
> on a hard drive and i cant see any of the folders any way as when i
> click on the drive with the left click it ask me if i want to format.
Nathan gave you the answer to your problem as you stated it. What you
didn't do is read the entire article and/or give all the necessary
information in order for someone to help you fully. Also, you seem to have
a strange habit of responding to your original post instead of responding
directly to the responders, keeping the thread intact. Please, try and keep
the thread intact so everyone might know what has been suggested/tried by
you. It does assist in helping you.
As long as EFS is not involved:
How to Take Ownership of a File or Folder in Windows XP
http://support.microsoft.com/?kbid=308421
How to disable simplified sharing & set permissions
on a shared folder in Windows XP
http://support.microsoft.com/?kbid=307874
Read through those articles. As I am unsure whether you have Windows XP
Home or Windows XP Professional, I will point out what the first article
does, to have a more complete answer directly here:
** Note You must be logged on to the computer with an account that has
administrative credentials. If you are running Microsoft Windows XP Home
Edition, you must start the computer in safe mode, and then log on with an
account that has Administrative rights to have access to the Security tab.
If you are using Windows XP Professional, you must disable Simple File
Sharing. By default, Windows XP Professional uses Simple File sharing when
it is not joined to a domain. **
I do hope this assists you in your quest to solve your issue.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
monkUsa
It's an old thread, but the question was never answered. I had the same problem.
Here is a solution
http://www.youtube.com/watch?v=V2wkaMFsh04
Just in case the video disappears, here are the basic steps (which should be similar in all versions of Windows XP, Vista, 7 and possibly 8).
Stage 1: (this stage might not be necessary, but you can always reverse it later).
Disable simple file sharing - see article http://support.microsoft.com/kb/307874
Step 1 - Click Start, and then click My Computer.
Step 2 - On the Tools menu, click Folder Options.
Step 3 - Click the View tab.
Step 4 - In the Advanced Settings section, click to clear the Use simple file sharing (Recommended) check box.
Step 5 - Click OK.
Stage 2:
Take ownership of the whole hard disk see YouTube video link above or the steps are listed below.
Step 2 - Right click on the Hard Disk Drive that you want to take ownership of and select Properties.
Step 3 - The HDD properties window will appear; select the Security tab.
Step 4 - Click the Advanced button that appears in the Security tab.
Step 5 - A new window with the title Advanced Security Settings for your HDD will appear. Click on the Owner tab.
Depending on the version of Windows you are using, the options will now look different. Windows XP users can jump straight to Step 7.
Step 6 - Click the Edit button and another window will open.
Step 7 - Select a new owner.
Step 8 - Put a check mark next to the option that reads Replace owner on subcontainers and objects.
Step 9 - Click OK.
Step 10 - Each time a dialogue or question appears you can simply agree, click yes or OK to continue.
Step 11 - Enjoy!
<- Shenan ->
