Mensa,
So here's my situation. I have an external 500 GB HDD (Western Dig My Book, FAT32). It suddenly became not recognizable by any PC I plugged it into. I figured the USB 2.0 interface was bad so I took it apart so I could get directly to the SATA connections and then plug it into my PCs internal secondary SATA connection, move the data I needed over and go get myself a new external drive. I'm running Windows XP.
Well it ain't working. I've tried a couple of things:
1. connect to internal SATA connector of PC and boot the PC.
Outcome: Firstly checked the Bios (F1) and yes, it recognized the drive. However, when windows tries to boot, XP hangs and I have to force a physical shutdown. One time I was able to make it into XP, the drive showed up in Device Manager and in Explorer, however, when I clicked on the drive in explorer, the computer hung and had to do a physical shutdown.
2. Power up the PC to assure XP starts all the way up, then attached the SATA cable to the drive, click check for new hardware in device manager.
Outcome: the drive is recognized. Clicked on properties. First tab shows drive is enabled and working properly. click on the "volumes" tab and PC hangs. had to physical shutdown.
Tried it again. This time did not click on properties/volumes. Instead tried to fire up Western Dig Diagnostics program. That program starts running thru the "drive detection" step, but then dies.
Hoping someone can give me some more areas to focus or things to try.
Thanks for any assistance!
