G
Guest
Guest
Hello all. I need some help and explanation!
I just crossfired 5850's today. My main monitor that i play games in is the Acer G24 (1920x1200 native res [dvi]) My 2nd monitor is Acer S243HL (1920x1080 native res [hdmi]) . Before the crossfire both my monitors was sharp and had very clear text. After i cross-fired it and updated the drivers i noticed my 2nd monitor fonts was very blurry and off while my Main monitor hadn't changed!!
It was driving me nuts, i finally had a way to fix it! i had to go to CCC and enable "GPU scaling" on the Acer S243HL.
1) IS this the correct and only way to fix my blurry-ness on my 2nd monitor?
2) Why did this happen after the cross-fire and updated drivers?
3) What exactly is GPU scaling?!?!?
4) What cons are with GPU scaling?
5) does it slow down my computer?
I'm so lost. i feel that after a not so needed crossfire upgrade i made my computer worse =*(
My Specs below:
Monitor 1: Acer G24 (DVI)
Monitor 2: Acer S243HL (HMDI)
OS: Windows 7 Home 64bit
Mobo: Asus P6X58D-E
CPU: i7930 LGA 1366
Memory: Corsair XMS3 6GB 1600mhz
GPU: Sapphire ATI Radeon HD5850 crossfire
PSU: Corsair TX 750TX
Case: Antec 900 (comes with two 120mm intake fans -med setting and rear 120mm exhaust and 200mm Exhaust fan on high setting)
HDD: WD Caviar Black 1TB
Case fan (intake): Thermal Take Smart X 2 (set on med. setting)
CPU cooler: Cooler Master
Hyper N520 (stk TP)
ODD: Phillpes x 22 (from previous computer
Keyboard: Logitech G110
Mouse: Razor Abyssus
Thanks all!
My Specs below:
Mobo: Asus P6X58D-E
CPU: i7930 LGA 1366
Hyper N520 (stk TP)
Thanks all!
